Limiting number of calls on SIP Trunk
I set up a SIP trunk between CCME 3.2 (on 1841) and CCME 3.3 (on 2611XM). We've only 128 kbps of bandwidth. Use G729r8 with RTP header compression.
Does someone knows how to configure a limitation of simultaneous calls that could be handles on the trunk ?
Thanks in advance.
Hall of Fame Super Gold
Re: Limiting number of calls on SIP Trunk
Hi, this is how you do that:
dial-peer voice 100 voip
session protocol sipv2
max-conns 4
Seem strange that you have CCME on the 1841 that does not supports CCME ?
Thank you.
It was very helpfull.
I have rated your post.
Yes, 1841 does CCME Version 3.2 in c1841-spservicesk9-mz.123-8.YG4.bin IOS.
Good to know.
Thanks for the nice rating and good luck!
111
