limiting the duration of an offnet call
dhillon_pta
hi folks...
-we r using CCM 4.0 and MGCP gateway (3745 router)
-e1 PRI for connecting to PSTN
can we limit the duration of an offnet call to PSTN such that after a specified number of minutes the call should be automatically disonnected.
thanx in advance
gogasca
Level 10
Level 10
Yes try, Maximum Call Duration Timer (min)*
CCMAdmin | Service | Service Parameter | Cisco CallManager | Advanced
This parameter specifies the minutes that a call can remain active before Cisco CallManager clears it. A value of zero disables the timer.
This is a required field.
Default: 720.
Unit: min.
Minimum: 0.
Maximum: 35791.
It will affect both Onnet and Offnet.
sorry sir, but i cudn't find the
"maximum call duration timer" in the specified path.
are u sure it is there at same place in CCM 4.0?
My bad, Maximum Call Duration Timer" service parameter is only from next Call
Manager versions: 4.1(3)sr1.
