Line and Speed Dial modifications: "Update failed" on 7961
zzbronski
This is the error I am getting when trying to add speed dials to the 7914 which is attached to the 7961. The 7914 module is selected on the expansion module section.
"Update failed. [2701] The Phone Template model and protocol do not match the device model and protocol"
7 Replies 7
testeven
Hi!
Is this a SIP phones? Can you check this bug CSCsh71913?
Regards, Tere. If you find this post helpful, please rate! :)
No it is SCCP.
Rob Huffman
Hi Kimble,
Just a question here, are you making these changes via BAT?
Rob
No, but I did use BAT to make a template for the same model phone, 7961 sccp.
Hello Rob,
I am having similar problem. We are migrating phones from 6.1.4 to 7.1.5 Call Manager. I am using BAT to do export and import.
When I do import of 7962 phones, I have this "Error 2701 The Phone Template model and protocol do not match the device model and protocol".
I created the phone template with correct available phone template.
I don't know if there is a bug associated with this. Please help.
Yogesh
Yogesh - let's discuss offline.
a.benner@verizonbusiness.com
Beau
I got this fixed... I had to recreate customized phone templates...and it worked.
