Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Line group and Hunt Pilot
Dear Team,
I have a 20 numbers of users with same department, i want to add them  in single phone group so that any one got calls from outside. May i know what is best Line group or Hunt Pilot.
hari
hari
Re: Line group and Hunt Pilot
You create a hunt pilot with a hunt group choosing how you want to alert every one and add all 20 ext or you can create a pickup group and assign it to each user so anyone can answer the call belonging to the pickup group
Voice CCIE #37771
Thanks.
but can we do this thrugh adding member in Line group.
hari
hari
Yes it should work to alert the end user
Voice CCIE #37771
Thanks for quick response
hari
hari
You're very confused on this, it's not one or the other, they're not separate options, a line group without a hunt pilot does not work, and a hunt pilot without a line group doesn't work either.
They're both part of the very same config and you need both, along with a hunt list. It's a 3 piece configuration.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Thanks Java.
hari
hari
147
