Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Line Group - Circular
I have a customer who would like their calls to circulate. For example, when someone calls upon a pilot number, Phone A will ring first, if no answer or busy, Phone B will ring second, if no answer or busy, Phone C will ring third... but if phone C no answer or busy, Phone A will ring again... then Phone B ring etc.
Is this possible with the 'Circular' alogthirm on Line Group??
Or would i need to create 2 line groups and split the users in half and let them hunt each other??
Would appreciate your help.
Cheers,
Hunt
Silver
Re: Line Group - Circular
Yes, you can accomplish this via the circular algorithm (see attached). Set the RNA reversion timeout for each member and add additional line groups onto the hunt list if necessary.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_1_3/ccmcfg/b03lngrp.html
Please rate if useful...
just keep in mind that circular will not always start with member A, it will extend the call to the next member taking into consideration the one that took the call before.
if you have A,B,C,D and C took the last call next one to receive a call would be D and it only will go thru the group one time.
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
147
