Line Group
I have cucm 7.0
Have configured a hunt group with 3 extensions.
Have set the pilot for DDI.
When I call in from PSTN. It only calls two extns. never the third. Does this all the time.
If you call the pilot internally, it works fine.
I can only assume there is something on the gateway causing this.
any ideas
Re: Line Group
You can try to use a translation pattern to your E.164 number] then put the hunt pilot [another internal extension]
in the called party transformation mask [another internal extension]
thanks
Re: Line Group
thanks for your reply.
I am not sure what this is going to achieve?
131
