line monitoring on CKEM-36 BLF feature?
tdudas
Hi All,
I'm trying to configure CKEM-36 with "speed dial BLF" buttons (attached to a 9971).
I would like to have monitoring feature enabled on the programmed extensions, but it seems when an extension is busy, there is no indication on CKEM button associated.
I have Phone button template configured, and applied on the phone, I can see the configured extensions on this expmasion module as well.
Thanks in advance!
Thanks!
Tibor
2 Accepted Solutions
Chris Deren
So, you do not see the status updates?
Make sure you have applied correct "Subscribe CSS" to this phone.
Chris
Rob Huffman
Hi Tibor,
Are you using CME or CUCM for call control?
Cheers!
Rob
5 Replies 5
Chris Deren
Chris
Hi Chris,
Thanks for your help!
It solved the issue!
Kind regards,
Tibor
Rob Huffman
Hi Tibor,
Cheers!
Rob
Hi Rob,
It is a CUCM (forgot to mention....)
Don`t forget you also end to subscribe to the CSS on the END USER page as well
