Line Reorginazation
sequent-is
Is there an easy way to reorganize where lines are placed on phones? Customer has 20 7961's and would like lines positioning changed around.
jbarcena
Level 9
Level 9
Actually for only 20 phones I recommend you to do it on the CCMAdmin webpage, is the best way.
Besides that you can use BAT, make an Export all Details of the phones, then open the file and cut and paste the lines in the order that you want, then delete the phones and make an import all details of the file that you just modified.
Keep a copy of the file that you exported just in case.
//Jorge
