Line Status for Call Lists - CUCM 9.1
Hi All,
As per the New & Changed information notes for CUCM 9.1  new feature released for 69XX phones to get the license status. But i unable to see the "Line Status for Call List" in enterprise parameter.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/9_0_1/delta/CUCM_BK_N38FD301_00_cucm-new-and-changed-90_chapter_011.html#P069_RF_L3E374A1_00.
Has anyonce experinced this ?
Maybe you are searching for BLF call list?
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,
Thanks for the Reply. I also suspect the same . But in the Guide they mention the parameters in the "Enterprise Parameters"
Re: Line Status for Call Lists - CUCM 9.1
The blf call list setting Is on enterprise parameters
Carlo
Hi Carlo,
I'm looking for  Line Status for Call List in Enterprise Parameter.
Hi.
As you can see the doc you posted is for 9.0(1) release not for 9.1.
Anyway line status  (or BLF) call list is the feature you are searching.
Carlo
159
