Community Member
Line Text Size in 7916 Expansion module
Dear networkers,
I have installed CCM v 8 cluster.
I have some 7065 IP Phones with 7916 expansio module installed. Users find that the text size of the 7916 lines is too small. Can we change the size of the text line ??
I did not find any parameters to change in the CallManager
Thanks in advance.
The font size is not something you can change.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Community Member
In the newer versions is there any update about this feature??
Kind regards,
Joel
478
