Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Lines on a 7941
I have 7941's deployed througout our office and I am wondering if there is any way to have the extension for the user show up on both buttons, i.i I have ext. 301 and I want both buttons to have that extension assigned to them. This is on CM 5.1
Re: Lines on a 7941
What functionality are you looking to implement with this configuration? Are you looking to implement a rollover line? An extension may only appear on one button on a phone. The second extension would need to be in a different partition. Let us know the functionality you are looking for, as there may be a different way of implementing it.
Hall of Fame Super Red
Re: Lines on a 7941
Hi Nicholas,
This is just a note to add to the correct hint from Michael (5 points for this one Michael!)
This method was used in older 3.x builds before the Multiple Calls per Line was added in 4.x
We still use this for some users who prefer the visual aspect of this setup;
This document shows how to use Partitions and Calling Search Spaces to configure multiple lines on one phone with the same DN. It is assumed that the user wants all incoming calls to start on line 1 and forward to subsequent lines if line 1 is busy.
Configuring a Single Dialed Number on Multiple Lines
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008009409c.shtml
Hope this helps!
Rob
207
