Link to verify upgrade CUCM 7.X to 8.X
Some days ago I was looking info about how to upgrade from UCC 7.1 to 8.X. There was a post with a link which shows a tool where I can select the current version of UCM and the version 8.X to which I could upgrade.
unfortunately I did not save the link, I have spent many hours trying to find the link once but I haven't could :-( .
Does any of you have that link?? I'd really appreciate your help.
regards,
1 ACCEPTED SOLUTION
Re: Link to verify upgrade CUCM 7.X to 8.X
You mean this?
Unified Communications Manager (CallManager)  Upgrade Tool
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080b31514.shtml
You can get the same info by looking at the SW compatibility matrix.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
You mean this?
java
java
Hi Java,
That's it !!!
Thanks a lot for your help.... and  5+   for you
333
