Linksys IP phone SPA942 does not register in CME 4.0
I tried to register an IP phone SPA942 in CME but it does not register.
voice register global
mode cme
source-address 10.10.10.1 port 5060
max-dn 5
max-pool 5
date-format D/M/Y
voice register dn 1
number 325
call-forward b2bua busy 600
call-forward b2bua noan 600 timeout 15
name filoooooooo
label 325
voice register pool 1
id mac 000E.08De.048a
number 1 dn 1
max registrations 48
dtmf-relay sip-notify
username 325 password 325
codec g711ulaw
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
h323
sip
subscription maximum accept 5
registrar server expires max 600 min 60
what it could be left so that I can get register the phone?
1 ACCEPTED SOLUTION
Re: Linksys IP phone SPA942 does not register in CME 4.0
I just configured a SPA941 today so I will assume its close to the same. I had the same issue until I opened up the web console of the phone. Click on Admin Login at the bottom select the line you want to configure "EXT 1". If you are using username and password put that information in the Subscriber Information section. After I did this it registered with no problems. Make sure "Use Auth ID" is set to yes and that the CME address is input in the Proxy and Registration section.
Hall of Fame Super Gold
Config is fine, check phone settings. If the phone is local to the lan, you can also eliminate username/password.
Then if you want to see what's going on, do"debug ccsip message" with "term mon".
Hi dannypuckett
I followed your recommendations and now the phones are REGISTERED !!!!!!!!!!
Thank you so much, I really appreaciate your time for answering.
1016
