Linksys PAP2T Power led says "SOS" !?
Hi there !
My Linksys PAP2T  is suddenly OOO and power LED says "SOS" !
I can't enter the setup with the IP address.
Whar appens ?
What can I do ?
Thank's for your help !
Snoopy
Hi Snoopy,
Check out the following document:  https://supportforums.cisco.com/docs/DOC-9901
Also, you would receive more help in the Small Business forum.
HTH,
Chris
Re: Linksys PAP2T Power led says "SOS" !?
Hi Chris !
Thanks for the document but ... what can I do now ???
Snoopy
2012/2/5 clileikis
Home <> Re: Linksys
PAP2T Power led says "SOS" !? created by clileikis<>in
IP Telephony - View the full discussion<>
After years of stability, my PAP2T-NA abruptly started flashing the SOS code.  The recovery tool referenced at
https://supportforums.cisco.com/thread/2021677 was unable to find my device, so I assumed it was dead and ordered another one.  When it arrived, I disconnected the old one, connected the new one, and it promptly flashed the SOS code, too!  The recovery tool was unable to find that device, either, and at some point I decided to connect both at the same time.  To my amazement, the recovery tool found the one I connected to the new power adapter.  I swapped adapters and the other one was found, too!  A multimeter measured 5.1VDC for both power adapters, so I can't explain this behavior, but in my case the only problem was the power adapter!
4329
