02-17-2008 09:47 AM - edited 03-15-2019 08:53 AM
I have been able to register a LinkSys SPA942 [ firmware 5.1.15(a) ], as a basic third party sip device on CM6.
As a Basic device, it seems to support only 1 line appearance.
However, I cannot get it to work as an advanced SIP device (8 line apparances).
Has anyone got this to work ?
02-27-2008 10:22 AM
i need that too! did you get it '
02-27-2008 11:40 AM
Yes, I did.
On the 942 admin page, I set the userId = AuthId, and set "Use Auth Id" to false.
On the CM Side, it uses the SIP Advanced security profile, and the digest user = the phone user id.
HTH.
03-06-2008 06:51 AM
can you be more splicit? i dont understand!! do you make anything on router? what i need to config on the router, on the CCM and the phone?
