Community Member
LinkSys SPA 942 on CM 6
I have been able to register a LinkSys SPA942 [ firmware 5.1.15(a) ], as a basic third party sip device on CM6.
As a Basic device, it seems to support only 1 line appearance.
However, I cannot get it to work as an advanced SIP device (8 line apparances).
Has anyone got this to work ?
Community Member
Re: LinkSys SPA 942 on CM 6
i need that too! did you get it '
Community Member
Yes, I did.
On the 942 admin page, I set the userId = AuthId, and set "Use Auth Id" to false.
On the CM Side, it uses the SIP Advanced security profile, and the digest user = the phone user id.
HTH.
Community Member
can you be more splicit? i dont understand!! do you make anything on router? what i need to config on the router, on the CCM and the phone?
168
