03-13-2009 04:14 PM - edited 03-15-2019 04:51 PM
Our company is using a homegrown Asterisk VoIP server solution. We use DHCP and TFTP to auto-configure Linksys SPA phones. When we
change the configuration, we would like the phones to reload the config
files. Maybe we could use multicast to force the phones to restart
and/or reload the configuration since we know that Linksys phones
respond to some multicast commands. Where can we get the list of those
multicast commands, possibly with details (packet formats, command codes)?
03-13-2009 07:10 PM
Hi, if this information is not in the document called "remote provisioning guide", I don't think you can find it anywher else.
03-16-2009 08:07 AM
Thanks. I will look for it.
03-16-2009 08:31 PM
You are welcome. Please remember to rate useful posts with the scrollbox below.
03-17-2009 08:57 AM
For the record, the doc I found is entitled spa_provisioning_guide.pdf
