02-23-2007 09:18 AM - edited 03-14-2019 08:11 PM
i have registred de SPA941 in the CME, but outgoing call doesn't work.
03-13-2007 05:31 AM
now all works correctly and fine,
the Linksys SPA 941 are registred in the CME and the CME is registred to the ITSP with sip-ua, and incoming/outgoing calls works witout problems.
there are 2 configuration , one for translation using the same number registred in the ITSP for many linksys phones and the second configuration using one sip-ua for one linksys.
02-28-2008 03:08 AM
02-28-2008 03:40 AM
What the phone is doing ? If it is local to the cme lan you don't even need username and password and it should register.
02-28-2008 04:53 AM
the phone do nothing.. the phone has no sound
02-28-2008 05:03 AM
Have you configured the phone using the web interface to phone address ?
02-28-2008 05:06 AM
no. what i need to configure ?
02-28-2008 06:25 AM
As a minimum, your number, proxy and register address.
If you do not want to do these things, use cisco IP phones, as they are controlled by the router and do not need additional configuration.
02-28-2008 07:45 AM
i have been try that too, but nothing. In the web of the phone i have to configure any user or password? i didn't see that menu
02-28-2008 08:50 AM
This is how you configure and administer linksys phones:
02-29-2008 12:40 AM
the configuration on the router are all right ? i don't have line on the phone. i have configurated the phone on web brower but still don't work! what iam doing wrong ?
02-29-2008 03:28 AM
Router seems right. Do the phone register ok ?
"debug ccsip message" and "term mon" will tell.
