List of allocated, free and used DDI's and ext's in Call manager..
Is there a way to find out what number range that has been installed on our call manager and a list of free numbers and numbers in use?
If so.. how would I go about obtaining it?
1 ACCEPTED SOLUTION
Re: List of allocated, free and used DDI's and ext's in Call man
you can only get a list of what you have configured, not sure what you mean "in use"
you can use the route plan report and it will show you what is configured on the server, but CUCM has no idea of whether someone is using it or no.
Also CCM does not differentiates between a DDI and anything else. They're all DNs and that's how CUCM sees them. Unless you have DDI on the description there is no way to tell.
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Just to clarify.... it has to contain the following..
DDI's in use
DDI's not in use
Ext in use
Ext not in use
... any help appreciated..
javalenc
java
Ok Thanks Jaime... I thought so but just needed clarification as user is insisting that "there should be some kind of feature present"
587
