Community Member
List of Downloaded Files
Hi Guys,
I am looking to list all the upgrade files downloaded to the call manager or to the unity connection
Anyone has an idea how to list them ?
2 ACCEPTED SOLUTIONS
Re: List of Downloaded Files
Hi.
You always need to upload it again via ftp or sftp.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Purple
Hi ,
After u download the files from Cisco site, u can verify the MD5 checksum before uploading to Call Manager and compare.
As said by Carlo, u need to use sftp software to upload the files in call manager cluster.
at the end, you Restart the tftp service .
regds,
aman
Purple
You can use the command file list tftp * from CLI of CUCM.
regds,
aman
Hi.
Also show version active through CLI should show all installed software.
Carlo
Community Member
Thanks Guys for the response, but i downloaded the files using FTP not TFTP and there is no file list FTP
i need that because sometimes i get error in installation and i need to re-install the same file without download it again.
file list activelog installed_options here are the istalled files
Carlo
Community Member
Great Carlo. I could see the downloaded file
the question now, How i can re-install the software using the downloaded file ?
Hi.
Unfortunately this is not an option :(
What you can do is download files from cucm and use them again via FTP/SFTP.
To get files use
file get activelog installed_options/fileyouneed
Carlo
Community Member
dear,
i don't want to get it, I need to start install the file in case i get error in the installation and i want to try again
Hi.
Carlo
Purple
Hi ,
regds,
aman
156
