List of SoftKey options
Is there a list anywhere of softkey options, during various phone states?  We will be using UCM 7.1
I checked the SRND, and it references lots of softkey features, but not as a single list.
Thx
Everyone's tags (1)
1 ACCEPTED SOLUTION
Re: List of SoftKey options
One of our end user cut sheets has a list for softkeys (built on cucm ver 7.1.3bsu2).  Here is the list:
Softkey-OnHookSoftkey-ConnectedSoftkey-HoldSoftkey-Ring-InSoftkey-OffHookSoftkey-ConnectedTransfer
RedialHoldResumeAnswerRedialTransfer
New CallEnd CallNew CalliDivertEnd CallEnd Call
Forward AllTransferSelectDnDForward All
QRTSelectJoinPickup
DnDJoinDnDMeetMe
Video ModeConferenceiDivertGroup Pickup
HlogConference ListDirect TransferOther Pickup
Remove Last ConferenceDnD
iDivertAbbreviated Dial
Mobility
Video Mode
Park
Softkey-DigitAfterFirstSoftkey-Connected ConferenceSoftkey-Ring-OutSoftkey-OffHookFeatureSoftkey-RemoteInUse
Abbreviated DialConferenceEnd CallRedialBarge
End CallEnd CallDirect TransferEnd CallcBarge
Call BackNew Call
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Unfortunately there is no doc that has each and every single key and what it's used for, the softkeys are mentioned in the documentation of the feature they're related for.
You can always go to the softkey config in CUCM and click on change layout.
Whatever valid softkeys appear, are the ones available per call state.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
QRTSelectJoinPickup
DnDJoinDnDMeetMe
Mobility
Video Mode
Park
Call BackNew Call
HTH.
Bill
Hall of Fame Super Red
Very helpful Bill!
+5 my friend
Cheers!
Rob
Great help, +5 indeed. Thanks
353
