Listen to radio dispatch traffic on IP phones
Customer has a request to allow IP phone users (possibly dozens)to listen to live radio dispatch at any time. Only connection from the dispatch system is an analog output. E&M port to FXS port? Multicasting?
Re: Listen to radio dispatch traffic on IP phones
Hi!
Using a soundcard in the CUCM server you could set up a Music On Hold server which plays a radio stream to callers while on hold.
You would need to connect a radio using a standard audio cable to the soundcard which will then be able to stream the music into your network.
But if you are looking to listen to the readio at any time from the IP phone speaker, this is not possible.
HTH, if it does, please rate.
Teresa.
Regards, Tere. If you find this post helpful, please rate! :)
I think 'impossible' is a little strong in this case. I seem to remember some options within the IP Phone Services SDK about receiving multicast audio to the speaker through a Phone Service, although that would require quite a bit of development. It is possible that this might be an option through Berbee's Informacast or IpCelerate's IpServer products.
VIP Super Bronze
Just to add two other options into the mix:
Syn-Apps.net has several good products in this arena. I'm not sure if they provide this exact solution though.
Any time I hear 'radio/dispatch' I think of Cisco IPICS:
http://www.cisco.com/en/US/prod/collateral/ps6712/ps6718/product_data_sheet0900aecd8034fd94_ps6724_Products_Data_Sheet.html
I am in contact with the customer about whether they think it worthwhile to look in the IPICS direction. Thanks for yourr input...
Multicasting should be the way to go. The config below takes an audio stream from an E&M port and converts it to an IP multicast.
voice-port 1/0/0
connection trunk 111
music-threshold -30
operation 4-wire
dial-peer voice 1 voip
destination-pattern 111
voice-class permanent 1
session protocol multicast
session target ipv4:237.111.0.0:22222
ip precedence 5
To connect to the audio multicast stream you should be able to write a basic IP service using the RTPMRx URI
Multicast Streams
Choose an option
Stream One
RTPMRx://237.111.0.0:22222
Useful links:
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t8/feature/guide/ft_hhip.html#wp1005920
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/all_models/xsi/5_0_2/english/programming/guide/ip502ch3.html
Please rate if helpful
Thanks for your info. It was very helpful. I now have a few ways to approach this scenario. I was also in contact with SingleWire (Berbee) about possible solutions and might have a way to go with an external USB MOH adapter and a phone service. SingleWire doesn't support it but they know it works.
Again thanks for your input.
Hi Jamesha,
I wanted to ask if there was anything important in the 'voice class permanent' config. You didn't add that to your example....
When I was putting together the reply I just cut and pasted the config from here.
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t8/feature/guide/ft_hhip.html#wp1013245
When I have set this up in the past I did not need the voice-class permanent command.
Got it, thanks. I'm going to study the doc in depth. I see the voice class commands, might as well put it in there. Does the virtual interface (vif1)need a specific IP address or just on a different subnet?
394
