Bronze
Live MOH from IPOD!!!
We have 3 CCM 4.13sr3c
It is running unicast MOH now...
we would like to have live MOH from IPOD now....
According SRND, we need audio card (Griffin Technologies iMic USB):
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_implementation_design_guide_chapter09186a00806e8c28.html#wp1043752
And for IPOD will use this cable connect to audio card.
http://www.amazon.com/Ipod-Dock-Conn-3-5MM-Cable/dp/B000J022G6
Is it going to work???
Second question, I know if we use unicast MOH, every time user put on hold, the music will start at the beginning. Is that will be same with Live MOH from IPOD???
Because we dont want start at the begninng, then I need to enable mulicast for live MOH...
Thanks a lot!!!
Ken
VIP Purple
Re: Live MOH from IPOD!!!
Ken,
Yes, this should work. Live MOH will not start from the beginning of the file, but will play whatever the live source is playing at the time. One thing to be aware of in this situation is that it is not legal to rebroadcast copyrighted music.
Hope this helps. If so, please rate the post.
Brandon
Bronze
Thanks your advice.
Bronze
One more questions,
If I install audio card and IPOD at Publisher.. if the publisher down... so what is my option??
Can you install audio card, and IPOD for all the CCM at cluster for redundancy??
Ken
168
