LLQ and general CBWFQ problems
Hi All,
Ive been playing around with different QoS techniques as i'm going for my exam fairly soon. I've read the exam cert guide and think i understand most of the concepts and configuration.
My understanding of LLQ is that it polices traffic.
With the config below im having two issues.
1. Traffic is not policed to 56k, it simply uses what it wants for RDP. If I use the police command instead then it works.
2. A lot of QoS policys I have tried do not always show the packets matched / bytes matched in the queuing section. When it clearly shows the class is being matched.
The below configuration shows the two problems i'm having.
I'd appreciate if anyone can shed some light, as it does not make sense to me!
class-map match-any PRIORITY
match access-group name RDP
policy-map PRIORITY
class PRIORITY
set ip precedence 5
priority 56
class class-default
interface Dialer1
bandwidth 256
ip nbar protocol-discovery
service-policy output PRIORITY
dover#show policy-map int d1
Dialer1
Service-policy output: PRIORITY
Class-map: PRIORITY (match-any)
683 packets, 173617 bytes
1 minute offered rate 0 bps, drop rate 0 bps
Match: access-group name RDP
1 minute rate 0 bps
QoS Set
precedence 5
Packets marked 682
Queueing
Strict Priority
Output Queue: Conversation 72
Bandwidth 56 (kbps) Burst 1400 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
Class-map: class-default (match-any)
4257 packets, 1967166 bytes
1 minute offered rate 35000 bps, drop rate 0 bps
Match: any
Re: LLQ and general CBWFQ problems
Just to add.
If I enable WFQ on the class-default and start up web streams, peer to peer, the queuing statistics don't show anything...Its weird, and annoying.
Hall of Fame Super Silver
LLQ does not police traffic it allows you to prioritize traffic based on your matching classes, so in your example you are prioritzing 56 kbps to your RDP class.
You did not show the RDP access-list, but my guess is that you are not matching the traffic properly hence not seeing it in the output of the "sh policy-map".
If you'd like to police traffic then, use the "police" statement in your policy-map.
HTH,
Chris
Hi Chris,
Thanks for your reply. Although, im still a little confised. Below is my access list and ive also included a snippet from the QOS book by Wendel.
Extended IP access list RDP
10 permit tcp any any eq 3389 (325411 matches)
"LLQ actually polices the PQ based on the configured bandwidth. By doing so, the packets in the queue that are forwarded still have very low latency, but LLQ also prevents the low-latency traffic from consuming more than its configured amount of bandwidth. By discarding excess traffic, LLQ can still provide bandwidth guarantees to the non-priority queues. The policing function works like policing as described in Chapter 6, but it is automatic in the low-latency queueno additional policing configuration is required."
When I police the queue to 56000, i get really bad performance from RDP. I should expect the same from using the priority 56 commands, except the class will always be serviced first?
Paul.
I think the snippet is from the Policing chapter and means when LLQ in conjunction with policing, such as:
Posted by: paul_alexander - Mar 7, 2007, 2:51pm PST
Hi All,
policy-map PRIORITY
class PRIORITY
set ip precedence 5
police 56000 conform-action transmit exceed-action drop
class class-default
interface Dialer1
bandwidth 256
206
