11-09-2010 10:23 PM - edited 03-16-2019 01:50 AM
Hi guys,
When ever i run topology services under campus manager it gives error Cannot create directory 'C:\Program Files\Java\jre6\lib\endorsed\'. I have added casuser with full control to that path. Restarted the server but no use. I am attachign screenshot for the same...Any idea how to solve this issue????
11-11-2010 07:30 AM
I am having the same issue ... any updates?
11-16-2010 01:24 AM
Have exactly the same issue with LMS 3.2.
Windows 7 32bit.
Is there any fix?
12-19-2010 03:58 AM
Hello Guys,
Any clue for resolvong my issue????????. lms 3.2 is installed on windows 2k3 std edition
12-19-2010 01:26 PM
try this. right click internet explorer/firefox and click run as administrator. then open the topology services. when it completes and says it needs to be restarted, close all your browsers, and logon the same way. once you get it up and running correctly, you wont have to logon this way anymore, with this computer. good luck.
12-19-2010 09:04 PM
I tried both, but still getting same error!!!!!
