Community Member
Load Auth Failed
We have inherited a bunch of 7961 and I get a Load Auth failed everytime.. We are currently running 8.5.1 the load information is set as
SCCP41.9-1-1SR1S can anybody share any light to this?
thanks
Hall of Fame Super Silver
Load Auth Failed
Delete the LSC certificate or perform factory reset.
HTH,
Chris
Community Member
Load Auth Failed
I have done factory reset still nothing
Load Auth Failed
How about deleting the ITL cert? Go to Settings -unlock the phone (**#) -> Security --> Trust List --> ITL and delete it.
Chris
VIP Super Bronze
Load Auth Failed
Shawn,
Doing a factory reset makes it worse. Because you are essentially defaulting the phone firmware to the firmware shipped from factory which I think is 8.3.2....Not all problems are solved by factory reset I learnt the hard way.
To upgrade to the firmware on the 8.5 servers which is 9.X series you need to hop first to 8.5.2. And from there you can jump to 9.X firmwares...
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hall of Fame Super Gold
Load Auth Failed
This is discussed in so many threads that you can search.
Must update to firmware 8.5.2 first.
Only after, you can update to any further firmware release.
Re: Load Auth Failed
Shawn,
As Paolo mentioned, the phone firmware MUST be upgraded to 8.5.2 first before going to 9.1.1 SR1. This is clearly mentioned in the release notes for firmware version 9.1.1 SR1
" For all SCCP firmware upgrades from firmware release versions earlier than 8.3(3) to version 8.5(2)SR1 or greater, you must first upgrade your firmware to version 8.5(2). Once you have upgraded to version 8.5(2), you can upgrade your IP Phone to version 9.1(1)SR1 or later. "
Therefore, it is always a best practice to read through the release notes guide of desired firmware version to avoid such issues. link to Release notes is always present on CCO page from where the firmware can be downloaded.
Hope it helps ?
GP.
Pls rate helpful posts by clicking on stars below the post !!
I don't believe factory reset downgrades firmware, it simply erases all configuration, certs, etc.
511
