Community Member
Load balancing over VG
Does Call Manager 6.1 with Voice Gateways such as 2800/3800 support call Load Balancing?
For example, When Route Gateways and Route Lists are configured for Let Say three Voice Gateways and each Gateway is configured with one Full PRI. Traditionally in a RL if the most preferred Gateway is unreachable then CM will look for the alternate path and so on, but I couldn't figure out a way where I could send outgoing calls in a Round Robin fashion. Is it possible?
1 REPLY
Re: Load balancing over VG
yes, the configuration is done within the route group to do that. you should have seen it because you need to configure them, instead of top down use circular algorithm
java
if this helps, please rate
java
www.cisco.com/go/pdi
117
