Community Member
Load Server - load files and upgrades
Phone Configuration
Product Specific Configuration
Indicates that the phone will use an alternative server to obtain firmware loads and upgrades, rather than the defined TFTP server. This option enables you to indicate a local server to be used for firmware upgrades, which can assist in reducing install times, particularly for upgrades over a WAN. Enter the hostname or the IP address (using standard IP addressing format) of the server. The indicated server must be running TFTP services and have the load file in the TFTP path. If the load file is not found, the load will not install. The phone will not be redirected to the TFTP server. If this field is left blank, the phone will use the designated TFTP server to obtain its load files and upgrades
Question:
We have CUCM 6.1.3 Multisite WAN with Centralized Call Processing, the firmware upgrades for branch sites over VSAT link are very slow.
What files of the CUCM tftp, I have to put in the local tftp server:
For example 7906
1- SCCP11.8-4-2S.loads
2- apps11.8-4-1-23.sbn
3- jar11sccp.8-4-1-23.sbn
4-
N-
Which is the complete list ?
1435
