05-18-2008 09:08 AM - edited 03-15-2019 10:43 AM
Is there anyway to present more than 100 entries in Local directory of CME?
Any workaround, any ideia to overcome the limitation?
Met.
05-18-2008 09:51 AM
Hi Met,
Here is one alternative;
Bulk-Loading Speed Dial Numbers
There can be up to ten text files containing lists of many speed-dial numbers that are loaded into flash, slot, or TFTP locations to be accessed by phone users. The ten files can hold 10,000 numbers.
Phone users dial the following sequence:
prefix-code list-id index [extension-digits]
SCCP: Enabling Bulk-Loading Speed-Dial
To enable bulk-loading speed-dial numbers, perform the following steps:
Prerequisites
â¢Cisco Unified CME 4.0 or a later version.
â¢The bulk speed-dial text files containing the lists must be available in a location that is available to the Cisco Unified CME router: flash, slot, or TFTP location.
Restrictions
â¢Bulk speed dial is not supported on FXO trunk lines.
SUMMARY STEPS
1. enable
2. configure terminal
3. telephony-service
4. bulk-speed-dial list list-id location
5. bulk-speed-dial prefix prefix-code
6. end
Hope this helps!
Rob
05-18-2008 02:16 PM
Rob,
I've read in another post about this solution. But for what i understand, it loads speed dials...but how do people make searches in the list?
Met.
