Community Member
Local Directory 100 entry limit in CME
Is there anyway to present more than 100 entries in Local directory of CME?
Any workaround, any ideia to overcome the limitation?
Met.
Hall of Fame Super Red
Re: Local Directory 100 entry limit in CME
Hi Met,
Here is one alternative;
Bulk-Loading Speed Dial Numbers
There can be up to ten text files containing lists of many speed-dial numbers that are loaded into flash, slot, or TFTP locations to be accessed by phone users. The ten files can hold 10,000 numbers.
Phone users dial the following sequence:
prefix-code list-id index [extension-digits]
SCCP: Enabling Bulk-Loading Speed-Dial
To enable bulk-loading speed-dial numbers, perform the following steps:
Prerequisites
•Cisco Unified CME 4.0 or a later version.
•The bulk speed-dial text files containing the lists must be available in a location that is available to the Cisco Unified CME router: flash, slot, or TFTP location.
Restrictions
•Bulk speed dial is not supported on FXO trunk lines.
SUMMARY STEPS
1. enable
2. configure terminal
3. telephony-service
4. bulk-speed-dial list list-id location
5. bulk-speed-dial prefix prefix-code
6. end
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmespeed.html#wp1010879
Hope this helps!
Rob
Community Member
Rob,
I've read in another post about this solution. But for what i understand, it loads speed dials...but how do people make searches in the list?
Met.
385
