Local directory callmanager 7.0
Hi All,
I am using CUCM 7.0. when I press corporate directory, it says "Error, Contact Administrator",
I already change the name to a ip address, not working
http://192.168.2.35:8080/ccmcip/xmldirectory.jsp
thanks
Dominique
1 ACCEPTED SOLUTION
Re: Local directory callmanager 7.0
If you put that link in your web browser do you get a response?
Select a directory
Personal Directory
http://192.168.2.35:8080/ccmpd/pdCheckLogin.do?name=undefined
Corporate Directory
http://192.168.2.35:8080/ccmcip/xmldirectoryinput.jsp
Cisco Personal Directory
Personal Directory Login
http://192.168.2.35:8080/ccmpd/login.do?sid=B8AAC4513078BE4DCF33601A033E2B0F
UserID
userid
A
john.user
PIN
pin
NP
Directory Search
Enter search criteria
http://192.168.2.35:8080/ccmcip/xmldirectorylist.jsp
First Name
f
A
Last Name
l
A
Number
n
T
Search
SoftKey:Submit
SoftKey:<<
Cancel
SoftKey:Cancel
Select a directory
Personal Directory
Corporate Directory
UserID
userid
A
john.user
PIN
pin
NP
Directory Search
First Name
f
A
Last Name
l
A
Number
n
T
Search
SoftKey:Submit
SoftKey:<<
Cancel
SoftKey:Cancel
working
thnks
Hi...
I'm getting the same error on a new CM7.0 installation.
When I press either Personal Directory or Corporate Directory, the screen displays Error, contct administrator.
Can you remember how you fixed yours?
Thanks... Phil..
How are using DNs resolve yes or no ?
If yes make sure you didnot configure the ip address on the CM7.0
If no put only the ip address
Dominique
Hi Dominique,
Yes we are using DNS. I've set the IP addresses in Enterprise Parameters back to the Name, and reset all devices.... Still getting the same error.
I think it might be a firmware issue. The phones have SCCP75.8-4-3S but I noticed there is cmterm-7975-sccp.8-4-4.cop.sgn available now.
I am going to try this now.
Phil..
Phil have you entered those links into a browser and see the results?
Hi Jay,
Yes, from an IE browser I get the following when I enter the URL http://10.12.0.10:8080/ccmcip/xmldirectory.jsp
Personal Directory
http://10.12.0.10:8080/ccmpd/pdCheckLogin.do?name=undefined
Corporate Directory
http://10.12.0.10:8080/ccmcip/xmldirectoryinput.jsp
Select a directory
And.. when I put http://10.12.0.10:8080/ccmcip/xmldirectoryinput.jsp into the IE browser I get:-
Directory Search
http://10.12.0.10:8080/ccmcip/xmldirectorylist.jsp
First Name
f
A
Last Name
l
A
Number
n
T
Search
SoftKey:Submit
SoftKey:<<
Cancel
SoftKey:Cancel
This indicates that the CallManager is working ok. I put a network analyser on this morning to compare what packets the non-working phone sends against the packets from a working phone on a seperate CallManager 6.1 system.
When I press Directory button on the working CM6 phone, I immediately see a 3 way handshake followed by a HTTP GET.
The debug shows: GET /ccmcip/xmldirectory.jsp?locale=English_United_States&name=SEP005056C00008 HTTP/1.1\r\n
(from the IP phone)
When I press the Directory button on the non-working CM7 phone I don't see any packets from the phone. However the scree still says "Error, contact administrator".
From this it looks like the phone, not the CallManager. I've upgraded the Firmware to SCCP75.8-4-4S but no luck.
Regards, Phil ..
Did you get a fix for this? Thanks
I did get the problem resolved. It turned out to be a problem with the CallManager name being used instead of the IP address. I was (totally) surprised this was the case, because I thought I'd set IP addresses instead of names everywhere.
If you still need to know, I'll fire up my VMware to refresh my memory..
Rgds,
Phil.
1513
