Local directory service not working
Hello all. I am using ccme 4.0 and 7970G-Ge Ip phone. I configured the directory numbers, however when I do show run..I do not see this line "local directory service: enabled." hence, my phones do not have access to the local directory..Please can any one help
1 ACCEPTED SOLUTION
Re: Local directory service not working
Also try,
telephony-service
directory-entry last-name-first (syntax may be wrong here)
create cnf-files
reset all
Green
AVVID6#conf t
Enter configuration commands, one per line. End with CNTL/Z.
AVVID6(config)#telephony-service
AVVID6(config-telephony)#service local-directory
Hi, I am not sure you got my post. I have this command configured on the router, however, My phones still do not have access to the local directory..is ther anything else I need to do.
Also try,
telephony-service
create cnf-files
reset all
If your still having issues with the local directory service, can you confirm that the "ip http server" is enabled in your config.
The Local Directory services require xml web services
Mike.
Thank you so much!!! You need to see how happy I am. Please I have one other issue...
When external calls come in, I do not see the the caller -id...It usually shows unknown number..Is there any thing I can do to see the caller-ids...
Hi, I observed that not all the phones have access to the local directory. Some do and some do not. This is disturbing. What I obserevd is that, in the device configuration menu on the phones, the phones that have access to the local directory have the directories url http://192.168.2.1:80/localdirectory on them while the phones that do not have access do not have this...How can i resolve this please..
Thank you
On further troubleshooting, I obserevd that,all the 7912 Phones have access to the directory services,including any new phones just configured or added to the cme.However its only the 7970 phone connected to the cme at the time I issued those set of commands ( telephony-service, directory last-name-first, create cnf files) that has access to the services. So the issue I have now is with the 7970 phones..Thank you
Just to let you know I have resolved the problem...The command..type 7970 was missing on the 7970 phones..That solved it.
230
