Community Member
Local installer + Cisco unified 7.0
hi,
i have downloaded the french local installer for the Cisco Unified 7.0.
but i dont find any document to install it.
plesae can someone help me?
thanks in advance
hicham
Hall of Fame Super Red
Re: Local installer + Cisco unified 7.0
Hi Hicham,
This is now installed via this method :)
This is done via OS Admin>Software Upgrades
Software Upgrades
You can use the Software Upgrades options to perform the following types of installations and upgrades:
•Install/Upgrade-Use this option to upgrade the application software, install Cisco Unified Communications Manager **Locale Installers and dial plans, and upload and install device packs, phone firmware loads, and other COP files.
•TFTP File Management-Use this option to upload various device files for use by the phones to the TFTP server. The TFTP server files that you can upload include custom phone rings, callback tones, and phone backgrounds.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/6_0_1/cucos/iptpch7.html
When using Cisco Unified CallManager Release 5.0 or later
For Cisco Unified CallManager 5.0, you must do all software installations and upgrades by using the Software Upgrades menu options. The system can upload and process only software that Cisco Systems approved. You cannot install or use third-party or Windows-based software applications that you may have been using with a previous version of Cisco Unified CallManager with Cisco Unified CallManager 5.0.
Using your web browser, login to the Cisco IPT Platform Administration web page
Under the Software Upgrades menu, select Install/Upgrade.
Fill in the appropriate values in the Software Location section for the file you downloaded above, and click Next.
In the Available Software drop-down box, select the file you downloaded above, and click Next.
After validating the MD5 has the correct value, click Next.
In the Warning box, verify you have selected the correct firmware, then click Install.
Check that you received a Success message.
Hope this helps!
Rob
I'm new to telephony and playing in a lab environment.
Are their compatibility issues if you have version CCM 7.0.2 and wants to install locale 7.0.1 ?
For locale I always see only 1 version 7.0.1. Or do I've to wait for locale 7.0.2?
I don't find a compability matrix or something like this.
Or is the locale numbering independent of the callmanager release. (Except for the major release number 7)
I found already that just the major release has to match
151
