Local significance for FAC in CUCM 7.1
Hi all,
Is there any way to deploy FAC on CUCM 7.1 in order to have local significance per site? I mean, a FAC code only to work in one site and not globally.
If not, do you know about a third-party applications that do this?
Thank in advance.
Juan Carlos
Everyone's tags (4)
1 ACCEPTED SOLUTION
No, any FAC is valid in any phone that calls thru any FAC enabled route pattern.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
java
java
Thanks for your quick response java, it´s what I was afraid of.
In order to have formal documentation, I´ll open a case on pdihelpdesk.
Juan Carlos
229
