Local Site can Call Remote Site but Remote Site Cannot Call Local Site
I have configured local and remote sites between CCM and CME
The local site uses call manager with mgcp gateway to ISDN PRI
The remote site has CME configured and it is connected to Local Site via LAN (Will eventually be fiber WAN).
I have configured the trunk and dial plan on local site CCM.
I have added an H323 Gateway on local site CCM and Remote CME
All of the local phones are able to call the remote CME extensions with no problems.
None of the remote site CME phones are able to call the Local site.
When dialing the extension on the Local CCM from the remote CME, the Remote phones all get a busy signal.
The current dialing Pattern should allow for an initial 6 and then a 4 digit extension
Here is the config on the remote CME site router :
version 12.4
service password-encryption
hostname TREC_VOICE_GTWY
boot-start-marker
boot system flash c2800nm-adventerprisek9-mz.124-9.T7.bin
boot-end-marker
card type t1 0 0
logging count
logging buffered 51200 warnings
no aaa new-model
resource policy
clock timezone CST -6
clock summer-time CST recurring
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
ip cef
no ip domain lookup
ip domain name sfccmo.edu
ip ssh time-out 60
isdn switch-type primary-ni
voice-card 0
no dspfarm
voice service voip
h323
voice class codec 2
codec preference 1 g729r8
voice class h323 1
h225 timeout tcp establish 3
controller T1 0/0/0
framing esf
linecode b8zs
cablelength long gain26 0db
pri-group timeslots 1-24 service mgcp
description TO CHARTER COMMUNICATIONS
controller T1 0/0/1
framing esf
linecode b8zs
interface Tunnel1
no ip address
interface GigabitEthernet0/0
description TO Network Switch
ip address 192.168.10.30 255.255.255.248 (Local LAN Temp Connection)
duplex auto
speed 100
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
ip route 0.0.0.0 0.0.0.0 192.168.10.25 (Core Layer LAN Switch)
snmp-server trap-source GigabitEthernet0/0
tftp-server flash:phone/7906-7911/SCCP11.7-2-1-0S.loads
tftp-server flash:phone/7906-7911/apps11.1-0-0-72.sbn
control-plane
voice-port 0/0/0:23
dial-peer voice 100 voip
incoming called-number .
no vad
dial-peer voice 6 voip
preference 1
destination-pattern 6T
voice-class codec 2
voice-class h323 1
session target ipv4:10.10.10.3 (Local Site CCM)
dtmf-relay h245-alphanumeric
no vad
telephony-service
load 7960-7940 P0030702T023
load 7941 term41.default
load 7911 term11.default
max-ephones 52
max-dn 192
ip source-address 192.168.10.30 port 2000 (Current IP of the this Remote CCM Router)
voicemail 2000
max-conferences 8 gain -6
moh music-on-hold.au
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp 7960 Oct 08 2009 09:44:41
ephone-dn 1
number 7501
label 7501
name Mark Haverly
hold-alert 30 originator
ephone-dn 2
number 7502
label 7502
description Happy Camper
ephone-dn 3
number 7503
label 7503
description Lonnie
name Lonnie
ephone 1
device-security-mode none
mac-address 0024.C443.73FA
type 7911
button 1:1
ephone 2
mac-address 001E.4A0C.1E47
type 7911
button 1:2
ephone 3
mac-address 001E.138C.BCEE
type 7911
button 1:3
116
