03-20-2014 07:25 PM - edited 03-16-2019 10:12 PM
G'Day.
Have a 2911 router with c2900-universalk9-mz.SPA.152-4.M4.bin. Configuration for local trancoder had been already in place but is unregistered. Need your inputs regarding the issue i'm experiencing. Also, i'm configuring SIP trunking to ITSP and cannot establish both incoming and out-going calls and I think the unregistered transcoder might be one of the cause. Attached are the configurations.
Solved! Go to Solution.
03-20-2014 10:00 PM
Your current sccp state should show up as:
Transcoding Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
Active Call Manager: NONE
TCP Link Status: NOT_CONNECTED, Profile Identifier: 1
Profile Operation State : RESOURCE ALLOCATED
Application : SCCP Status : ASSOCIATION IN PROGRESS
The reason your transcoder is not registering is because you don't have the following commands under telephony-service
max-dn
max-ephone
Run these 2 commands under telephony-service and then do show sccp. It should work fine.
03-20-2014 08:06 PM
The sccp and dspfarm profile config looks good, can you share the 'show sccp' output as well.
Manish
03-26-2014 01:53 AM
Have added max dn and trancoder is able to register.
03-20-2014 10:00 PM
max-dn
max-ephone
