LOCAL USER LANGUAGE WON'T CHANGE CUCM 9.1
hello guys
i have problem with a cucm 9.1, i download the file contine franch language for phones and i installed by ftp, in local user phone language show me that the phone in franch but physiqly it's in english.
it won't be change to franch even reset to factory..
is there any suggestion ???
is there are any one face the same problem before ???
VIP Super Bronze
Did you restart TFTP after installing the COP file?
Did you reset the phone? It needs to download the COP file from TFTP.
To confirm: the User Locale field on the Device Configuration page is what you're referring to, correct?
Please remember to rate helpful responses and identify helpful or correct answers.
Yes i restart the service and after that i restart the server but with no result, i restart the phones to but with result.
VIP Purple
Did u restart the server after uploading the locale?
regds,
aman
YES
VIP Purple
Hi ,
Can u try uploading the Locale again using SFTP and then, check.Please refer the link.
http://docwiki.cisco.com/wiki/Cucm-phone-locale-installers#CUCM_User_Locale_and_Network_Locale_support
regds,
aman
thank you but it's not work
thank you guys i find the solution
the cause was the firmware
VIP Purple
Hi ,
thanks for update.
can u update what was the earlier version and the version on which problem has been resolved ?
what was the phone model ?
regds,
aman
hi
earlier version was 8.1.2
the new version is 8.3.1
BEST REGARD
Hi youssef ,
Hi youssef ,
I have the same problem, as you solved it?
Thank you
720
