Locale change on 6941 at CUCM 7.1(5) fails
I've got a 2-node CUCM cluster running 7.1(5) and some 6941 phone with firmware release 9.0.2. The phones should speak Japanese, German and Dutch by choice.
I've installed those locale-packages:
cm-locale-combined_network-7.1.5.1000-1.cop.sgn
cm-locale-nl_NL-7.1.5.1000-1.cop.sgn
cm-locale-ja_JP-7.1.5.1000-1.cop.sgn
cm-locale-de_DE-7.1.5.1000-1.cop.sgn
and those found als "endpoint locale installer" in the 6941 download-section at CCO:
po-locale-ja_JP-9.0.1.1000-1.cop.sgn (not available as 9.0.1)
po-locale-nl_NL-9.0.2.1000-1.cop.sgn
po-locale-de_DE-9.0.2.1000-1.cop.sgn
I installed all those packages on both servers and rebootet the cluster several times since this installation.
If I change the locale on a phone, the announcements are in the right language, but the phone menus stay english.
The EM-service seems to be in the right language, but if I try it in japanese, there are only small boxes instead of characters- it seems like the symbol set is missing.
If I sniff the phone's traffic using wireshark during the boot, I see that the fil rtl-sccp.jar from the appropriate language-folder is requested and as it looks also delivered. If I download such a file to my PC and unzip it, it contains right-looking resource files.
I've seen FW 9.0.2SR1 on CCO, but found nothing about this issue in the release notes.
Is there anybody with a similar problem who has found a solution?
Best Regards
Jörg
Everyone's tags (6)
Re: Locale change on 6941 at CUCM 7.1(5) fails
Hi joergwesely,
your fix the Problem?
I Have the similar problem, with the IP Phone 6921 firmware 9.0.2 in a CUCM 7.1.3. Dont display label in Spanish.
I install the cm-locale-es_CO-7.1.3.1000, but the problem continue.
Any updates on this case? I'm having same problems here trying to set the user locale in spanish. )-:
I have the same problem but then on UCME 8.1 with the Dutch language. I've another 8.0 installation with the same issue. A 7931 gets nice dutch softkey options but the 6941 stays in English.
Marcel.
I have opened a TAC with Cisco and here is the response:
-       Unfortunately localization will not be available on CME for 69XX phones until CME 8.6
-       CME 8.6 will be released till March 2011
-       You can contact Cisco after March 2011 for Spanish locale on 69XX phones
So, we will wait until March 2011.
Camilo
Hi everyone,
I've encountered the same issue on CUCM 7.1.5-10000-12
I installed "po-locale-sl_SI-9.0.2.1000-1.cop.sgn", rebooted CM & TFTP services and nothing happend, phones remain in english language.
I also rebooted both servers, but no luck.
Did enyone get any news on this matter?
Kind regards!
Ales
3348
