Community Member
Locale CME 4.1
I am have problem with install locale Brazil.
I use the command:
archive tar /xtract tftp://192.168.1.1/cme-locale-pt_CN-4.0.3-2.0.tar flash:
My ip phone are 7970 so:
tftp-server flash:/zh-td-sccp.jar alias user_define_1/td-sccp.jar
I rename the the language_tags_file and language_utf8_tags_file
I create cnf-files
But in the user-local don't have the locale Brazil that i install.
I need to create a dir user_define_1?
Peterson
Bronze
Re: Locale CME 4.1
Simply configure user local Portugal and you will have resolved the language. Then for the the tones you can edit or replace the g3.xml file to set Brazil tones, but many times is not even necessary.
Hall of Fame Super Gold
Re: Locale CME 4.1
A post of mine copied verbatim above ?
One has to see anything in life :)
239
