04-26-2010 09:19 AM - edited 03-15-2019 10:28 PM
Hi, Does anyone know where I can find the Cisco Document for installing
new locales and which services need to be stopped and restarted.
Dominic
Solved! Go to Solution.
04-26-2010 12:54 PM
Hi Dominic
Enclosed is the link on how to install various Locales for a Call Manager 7.1 environment.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/7_1_2/cucos/iptpch7.html#wp1180342
We are running 7.1.3.100000-11 in our environment. Once the locales files have been installed on every server in the cluster, you will then need to re-boot every server in the cluster. We have 9 servers in our cluster (7 cucm servers and 2 tftp servers) and it took just over 2 hours to re-boot every server in the cluster.
Hope this helps.
Cheers
04-26-2010 12:54 PM
Hi Dominic
Hope this helps.
Cheers
04-26-2010 11:40 PM
Thanks for your help with that.
Regards Dominic
