Localization file (spanish) for 7942 IP phone in CME 8.0
I have checked the localization matrix for CME, the table show that there is support for localization for 7942 since CE 4.1. However the admin guide file
just covered
" Installing System-Defined Locales for Cisco Unified IP Phone 7906, 7911, 7921, 7931,7941, 7961,7970, 7971, and Cisco IP Communicator"
there no reference for 7942 model.???
Localization matrix  shows that the file es-mk-sccp.jar handles the localization for 7942/7962 phones but this file is just included in locale file
CME-locale-es_ES-4.1.0.2.tar     there no localization file for CME 8.0
My doubt is,
should I follow the same procedure for configuring localization on 7911, 7941 ?
should I use the file es-mk-sccp.jar for version 4.1 ??
regards,
paolo bevilacqua
Yes, it uses the same file.
