Localization on CME (Call Manager Express)
I'm using CME 7.0.0.1 . I want to use greek locale for 7906, 7942, 7962.
I'm following the instructions according to this document:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmelocal.html
and using the method with the Installer. The locale that i'm using is CME-locale-gr_GR-7.0.1.1.tar .
So every time i'm issuing the user-locale U1 load CME-locale-gr_GR-7.0.1.1.tar command i get the following error:
LOCALE INSTALLER MESSAGE:Loading Locale Package...
LOCALE ERROR: Failure renaming flash:/its/CME-locale-gr_GR-7.0.1.1.tar.cfg to flash:/its/user_define_1_CME-locale-gr_GR-7.0.1.1.tar.cfg ERROR#Unknown error 2573
%Error deleting flash:/its/CME-locale-gr_GR-7.0.1.1.tar.cfg (File not found)
I'm attaching sh run and some dir outputs to check my files.
I can;t understand what is happening. I cant find much of a use on cisco documentation.
Any help will be appreciated. Thank you
1 REPLY
Re: Localization on CME (Call Manager Express)
does anyone has any knowledge to share? Has anyone faced that problem before?
Thank you
436
