Community Member
Locating Subscriber across WAN
We are interested in moving a subscriber for a CCM 5.1 across our WAN for survivabiltiy.
How much bandwidth can I expect to be used by the CCM to keep current, or how much should we have? We have a small system of less then 200 phones, that rarely changes.
Andy
1 ACCEPTED SOLUTION
Re: Locating Subscriber across WAN
Database replication between publisher uses best effort (DSCP=0). The only recommendation from cisco for the replication traffic between pub and sub is that maximum RTT of 40 ms, 20 ms in either direction.
So based on your WAN setup, you should be fine enough, check the ping results across the wan and make sure the RTT is under 40 ms.
Can you provide more details about WAN network, bandwidth, layer-2/MPLS?
Community Member
Layer 3 MPLS
2 seperate T1s from Publisher site
a Bonded 3 meg circuit at the Subscriber site
Community Member
Layer 3 MPLS
111
