07-17-2014 07:04 PM - edited 03-16-2019 11:26 PM
+ CUCM 9.1.2
+ Need troubleshooting assistance for Location and Bandwidth Manager
+ Configured Location with 40000 bytes for Codec G711 to handle 500 calls
+ Assigned the same in SIP trunk (IP Provider) and phone with Hub_None
+ But I m seeing in the RTMT more than 500 calls active via this SIP trunk
+ Got confirmation from the service providers that CUCM is sending 517 calls during the peak hours.
+ Suspecting the issue with CAC (Location)
+ Any possible way that the location allows more calls than the bandwidth configured ?
07-18-2014 10:20 PM
Any ideas........
07-19-2014 01:51 AM
I think, we can't set specific number of calls in CUCM for a specific trunk, just we set bandwidth under location and codec in region.
You can verify it in a maintenance window by setting the bandwidth to 1 kpbs under location in CUCM after that call should not connect. If it doesn't connect then it means CAC is working otherwise needs to check logs/configuration.
Suresh
07-19-2014 09:51 AM
Perhaps some of your calls use different codec hence less bandwidth being used.
Alternatively you can also set restrictions on CUBE instead of CUCM.
Chris
07-19-2014 10:06 AM
Hi.
+5 to Chris as usual :)
... also verify that the location you cofigured is associated with the Device Pool assigned to the Sip Trunk.
Carlo
07-21-2014 06:26 PM
Hi Carlo,
Thanks for your reply, as you said Device pool has been configured without Location.
Now configured the same, will observe the calls during the busy hours and let you know.
