Community Member
Location-based CAC and RSVP-based CAC
How to enable the subject technology in order to block to calls in case of oversubscription.
Hall of Fame Super Silver
It is not just enabling these, first you need to figure out which one you want to use, second you need to plan carefully, calcuate your bandwidth, etc.
Please check out latest SRND for great explanations on both and some configuration examples:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/srnd/8x/cac.html#wpxref42460
HTH, please rate all usful posts!
Chris
Community Member
Forbidden File or Application
Green
Chis's link is valid and good  (+5 Chris )
just remove the "partner" word
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/cac.html#wpxref42460
Now try
Alex
Regards, Alex. Please rate useful posts.
Community Member
is it related to media resource? thanks
Green
Your original question asks about blocking calls due to
oversubscription of bandwidth.
This is easily carried out by setting the correct bandwidth at each LOCATION.
1 x G729 Call = 24 K
1 x G711 Call = 80K
So lets say the link between LOCATION A and LOCATION B  has a usable
VOIP bandwidth of 100K
This will allow 4 x G729 Calls or 1 x G711 Call
Any calls above these limits will be rejected with an INSUFFICIENT BANDWIDTH legend
appearing on the phone making the call.
Remember to make sure that the correct codecs are slected between regions.
Alex
Community Member
If i will set the Only the Location in CUCM as per you said this will be called as Locatioan-Based CAC ?
Following the is RSVP-Based CAC ?
sccp local Loopback100
sccp ccm 10.X.X.X identifier 2 version 7.0
sccp ccm 10.X.X.X identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 3 register abc_MTP
associate profile 2 register xyz_XCODE
associate profile 1 register mno_CONF
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 12
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
dspfarm profile 3 mtp
codec g711ulaw
maximum sessions software 10
1682
