Location Configuration in Centralized CallProcessing Deployment
Hello Friends,
In Centralized Call Processing, What is the parameters or consideration for configuring the Bandwidth in "Location" under CUCM which is different from reserving the RT Bandwidth for that particular site in Gateway?
Do we need to consider the On-Net, VMProfile, Announcements only or still there are more to consider to avoid any CAC issues.
Bala
1 REPLY
Hall of Fame Super Silver
Bala,This is well described
Bala,
This is well described in the CAC section of SRND, you can use the Hub_none location for centrelized resources.
Chris
17
