Location
I
I are reading about Location.
In call using g729, 24kbps is bandwith to call stream or to call?
I have 240 kbps on WAN
-Are 10 calls (10 x 24 kbps)?
or
-Are 5 calls (240 / (24 kbps x 2 call stream)?
VIP Super Bronze
Re: Location
Each g.729 call from callmanager is 24kbps/call.
Hence with 240 kbps, you can support 10 calls. But in real sense, it is actually less than 10 calls, beacuse of layer 2 overhead in your network.
So with 240Kbps, I will provision 9 calls.
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Re: Location
CUCM does not take layer 2 in consideration for location calculations.
for G711 consider 80 kbps per call and for g729 24 kbps per call for calculations.
thru the rest of the way you do need to take layer 2 in consideration for BW calculation.
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
100
