Lock Down Ring Settings
Does anyone know if there is a way to lock down the ring tone settings on certain phones? Running CM 4.2(3). Thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Lock Down Ring Settings
Hi Steven,
Here is a way of preventing specific users from changing the Ring Type;
Users are unable to change the Ring Type if you disable the Settings Access parameter on the Phone configuration page. Complete these steps:
From the Cisco CallManager Administration page, choose Device > Phone, and click the phone for which you want to prevent a ring type change.
Choose Disabled for the Settings Access parameter under the Product Specific Configuration section.
When Settings Access is enabled, you can change the phone network configuration, ring type, and volume on the phone. When you disable Settings Access, the Settings button is completely disabled and no options appear when you press the button. Also, you cannot adjust the ringer volume or save any volume settings. The option Restricted is available in Cisco CallManager version 4.1(3) and later. When you change Settings Access to Restricted, you can only access User Preferences and volume settings. By default, Settings Access is enabled.
From this doc;
http://www.cisco.com/en/US/products/hw/phones/ps379/products_qanda_item09186a00800a6763.shtml
Hope this helps!
Rob
Please remember to rate helpful posts........
Hi Steven,
From this doc;
Hope this helps!
Rob
Thanks. That worked great. I can't believe I missed that one.
230
