Community Member
Locking a phone
Is ther a way to lock a phone down thru call manager so nothing works on it. A phone located in a lobby where you do not want people to call out on it but only receive calls during certain hours.
How do you do this in call manager?
Silver
Re: Locking a phone
your friend is : Extension Mobility.
Community Member
Re: Locking a phone
Hi Mojo1
Firstly create a call partition called "internal calls" only.
They you will need to add a new "Route Pattern Configuration"
Then configure the DN of lobby phone with the call partition "internal calls"
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803ed685.html#wp1019359
Hope this helps!
138
