Locking down the "Settings" button on 7960 phone
Is there anyway to disable this button? I have security concerns with someone being able to access the network configuration on our lobby phone.
Thank you for your help.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Locking down the "Settings" button on 7960 phone
Hi Brian,
Give this a try, disable the Settings Access parameter on the Phone configuration page. Complete these steps:
From the Cisco CallManager Administration page, choose Device > Phone, and click on the phone for which you want to prevent access to the Settings Button.
Choose Disabled for the Settings Access parameter under the Product Specific Configuration section.
When Settings Access is enabled, you can change the phone network configuration, ring type, and volume on the phone. When you disable Settings Access, the Settings button is completely disabled and no options appear when you press the button. The option Restricted is also available in Cisco CallManager version 4.1(3) and later. When you change Settings Access to Restricted, you can only access User Preferences and volume settings. By default, Settings Access is enabled.
From this doc;
http://www.cisco.com/en/US/products/hw/phones/ps379/products_qanda_item09186a00800a6763.shtml
Hope this helps!
Rob
Hi Brian,
From this doc;
Hope this helps!
Rob
Rob-
Thanks so much. This exactly what I was looking for.
Hi Brian,
Good stuff! Glad to be of some help :)
Take care,
Rob
420
